Mouse movement as input translator
Post Reply [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
rogger4
New User
Post by rogger4 » Tue Aug 21, 2012 10:48 pm
First of all I would like to thank for this good piece of software. I use MT for controling lightning software with midi controler and programmable keyboard and a trackball.
But this trackbal is the problem. I want to control data entrys with a macro in the software with the trackball, but for that I need to translate a mouse movement and/or wheel movement, eg left, right, up, down in a MIDI Output.
So my feature request is: Could there be a mouse/wheel movement as input translator? ( could be also interesting for playing synthesizer, e.g. Pitch bend or rubato via mouse movement)
Greetings from Germany,
Kntu Blancke
Bome Software: Founder
Contact:
Re: Mouse movement as input translator
Post by florian » Tue Nov 06, 2012 11:05 am
Hi Knut(?),
yes, we consider adding this feature.
sjcaldwell
Power User
Post by sjcaldwell » Sat Oct 07, 2017 6:12 pm
Hi
Please see if the solution mentioned in this post will work for you.
https://www.bome.com/support/kb/midibud ... cHBvcnQ%3D
Post Reply
