MIDI CC-->Mouse Drag
Post Reply
bg
New User
Post by bg » Sat Sep 02, 2006 6:43 pm
Mouse movements/clicks as Outgoing Action
Status: in beta for "Midi Translator Pro"
I see mouse movements/clicks is being worked on. I have a suggestion/request that may be different.
The VST plugin Kantos, for example, has on-screen controls which cannot be automated by MIDI. You have to click-and-drag the on-screen sliders with the mouse. I am imagining a feature in MT called something like "Define Drag Region..." where the user would be prompted to click-drag a region. Typically the region would be the travel of an on-screen slider or knob. Then the user would be prompted to enter a MIDI CC number. MT would then move the on-screen slider/knob in response to incoming MIDI CC.
In order for a feature like this to work properly, the "Drag Region" would obviously have to be relative to the window that's being addressed. In other words, once an on-screen control is defined, the user should be able to re-postion the window (e.g. the VST plugin) and maintain the same MIDI-to-screen relationship.
I hope this makes sense.
Bome Software: Founder
Contact:
Post by florian » Mon Sep 04, 2006 11:30 pm
this definitely makes sense. It is somewhat specific, and it could be already done with the current implementation: you can separately press down a button and move the mouse. But of course it would be quite inconvenient to set up. I'll add it to the feature requests.
bg
New User
Post by bg » Tue Sep 05, 2006 2:51 pm
Thanks for the reply and for considering the request!
OiMutz
User
Post by OiMutz » Mon Jan 14, 2008 4:39 am
I have to say, this will be a stunning feature. I'll be jumping for joy if this gets implemented. Count me in for any beta testing. It may be harder to do in some DAW's (Like Cubase) where the windows don't use standard Window handles etc.
I'm using REAPER, which has transparent window titles and VST.
The audio community has been waiting a long time for something like this.
Contact:
Post by florian » Mon Jan 14, 2008 11:27 am
Hi OiMutz,
the latest version, 1.6.0, has Mouse emulation! You should check it out.
Post Reply
