Check Sum Error
Moderator: florian
New User
Check Sum Error
Post by srlees » Sat Oct 16, 2010 5:25 pm
Has anyone transferred .syx files via USB to a Alesis DM10 module? I downloaded the files it seems with out a problem from The DM10, saved them as a .syx file. Then when I try to upload it back to the module theI get a check sum error and a screen appears on the Alesis DM10 saying waiting for midi connection? How would I fix this?
Bome Software: Founder
Re: Check Sum Error
Post by florian » Sat Oct 22, 2011 4:45 pm
the typical problems are:
- faulty MIDI drivers -- you should update your MIDI drivers
- sending too fast for device -- you should configure Send SX to send slower (in the settings)
- broken MIDI cable
