How can i change the version number in commandline?
Moderator: florian
Locked
zashelsprosit
New User
Post by zashelsprosit » Tue Oct 07, 2008 12:46 pm
thanks in advance
ketpet
New User
Re: How can i change the version number in commandline?
Post by ketpet » Wed Oct 15, 2008 12:44 pm
zashelsprosit wrote:How can i change the version number in commandline?
thanks in advance
What command line ? If you mean, in resorces then just search it(version number) there.
It should be in one of the Dialogs or in one of the Strings there ;)
Then change the number between "".
Bome Software: Founder
Contact:
Post by florian » Mon Oct 20, 2008 2:39 pm
If you mean invoking Restorator with command line parameters to programmatically change a version resource (i.e. without GUI), check the help file:
Commandline parameters and scroll down to "Command Line Version resource editing".
Let me know if there are any issues.
Locked
