1 MIDI message to cycle 4 keystrokes
Post Reply
Jazzid
New User
Post by Jazzid » Mon Jan 07, 2008 11:13 am
Sending 1 midi message (a button on a keyboard) needs to cycle 4 keystrokes.
The key strokes are [Ctrl and 1], [Ctrl and 2], [Ctrl and 3], [Ctrl and 4]
After output [Ctrl and 4], I want the rule to cycle back to [Ctrl and 1] at next button-press.
I've fiddled around with the rules, but I've been unable to solve this one.
Can anyone point me in the right direction?
Regards
Jazzid
metastatik
Power User
Post by metastatik » Tue Jan 08, 2008 4:39 pm
You need 5 translators and they’d be set up like this.
Translator 1:
Options: Stop processing unchecked
Incoming: B0 01 pp (replace this with the MIDI message you want to use)
Rules: ga=1+ga (every time the MIDI message is sent, the value of ga will increase by 1)
If ga>4 then ga=1 (if the value of ga is greater than 4, the value of ga will return to 1)
Outgoing: None
Translator 2:
Options: Stop processing checked
Incoming: B0 01 pp
Rules: If ga !=1 then exit rules, skip Outgoing Action (if ga doesn’t equal 1, this translator will be skipped)
Outgoing: Ctrl+1
Translator 3:
Incoming: B0 01 pp
Rules: If ga !=2 then exit rules, skip Outgoing Action
Outgoing: Ctrl+2
Translator 4:
Incoming: B0 01 pp
Rules: If ga !=3 then exit rules, skip Outgoing Action
Outgoing: Ctrl+3
Translator 5:
Incoming: B0 01 pp
Rules: If ga !=4 then exit rules, skip Outgoing Action
Outgoing: Ctrl+4
Jazzid
New User
Post by Jazzid » Tue Jan 08, 2008 5:20 pm
Well, I realize that there are people out there smarter than myself. Not that that comes as a big surprise. :wink:
Anyway, thanks a lot for helping me out with this one. I can't wait to give this receipt a go.
I've been looking at the setup, and it seems really clever!
Metastatic, I owe you one :D
Aphid
New User
Post by Aphid » Sun Apr 05, 2009 5:10 am
This is almost exactly what I've been looking for - but there's one problem.
I'm using this for a beatjuggling hybrid I'm working on - the unfortunate part is that once it get's to the end of the cycle using the above code, it requires a fifth press to return to the beginning.
So, it goes 1st press, 2nd press, third, fourth and then to cycle back to 1, it requires a 5th press (the one where it determines that it needs to reset to 1, from 4).
We need to avoid this for a continuous cycle ie. 1,2,3,4,1,2,3,4,1,2,3,4 NOT 1,2,3,4. 5, 1,2,3,4. 5, 1,2,3,4 etc. Any suggestions?
ruediger
Bome Software: Partner
Post by ruediger » Mon Apr 06, 2009 4:42 pm
this should be easy.
Translator 1:
Outgoing: None
Translator 2:
Incoming: B0 01 pp
Outgoing: Ctrl+1
Translator 3:
Incoming: B0 01 pp
Outgoing: Ctrl+2
Translator 4:
Incoming: B0 01 pp
Outgoing: Ctrl+3
Translator 5:
Incoming: B0 01 pp
ga=0 (if the value of ga is greater than 4, the value of ga will return to 0)
Outgoing: Ctrl+4
Best regards,
Rüdi
Aphid
New User
Post by Aphid » Tue Apr 07, 2009 5:05 am
Wow it worked! Thank you so much!
:D Blam!!!!
8)
Post Reply
