remap midi channels
Post Reply
an3
Power User
remap midi channels
Post by an3 » Thu Jan 05, 2017 3:05 pm
im aiming to remap midi input ch 2 with a CC toggle between ch 2 and ch 1. not working though:
THE signal from channel 2 is being remapped to channel one, but toggling SHIFT doesnt change the channel remapping. i added (but disabled) a shift OFF (it s a toggle issnt it or ? ). So why is the toggle not remapping
see included file
remap Ch 1+2.bmtp
(3.76 KiB) Downloaded 66 times
sjcaldwell
Power User
Re: remap midi channels
Post by sjcaldwell » Thu Jan 05, 2017 3:16 pm
Maybe add a preset that initializes g0 and g1 to 0? Have it run when you open the project.
Uninitialized variables do not have a known state.
Then to simplify I would change
g0=g0+1
if g0>=1 then g0=0
to
g0=g0^1
Also with your logic if g0 starts out zero it will always end up zero.
an3
Power User
Post by an3 » Fri Jan 06, 2017 12:26 am
ehm, i really havent got the slightest clue where to start to make an initializing preset ?
and g0=g0^1 = he same as my version but shorter ?
kind regards
sjcaldwell
Power User
Post by sjcaldwell » Fri Jan 06, 2017 12:42 am
see attached
remap Ch 1%2B2a.bmtp
(3.88 KiB) Downloaded 141 times
an3
Power User
Post by an3 » Fri Jan 06, 2017 6:46 pm
tnx . im having a look at it right now. so the init thing just says, when starting bmt: ur on this value?
sjcaldwell
Power User
Post by sjcaldwell » Fri Jan 06, 2017 6:59 pm
an3 wrote:tnx . im having a look at it right now. so the init thing just says, when starting bmt: ur on this value?
Yep
an3
Power User
Post by an3 » Fri Jan 06, 2017 7:10 pm
great and working.
NOw i still have the problem, of the 3 presets i made: All modifying the midistream from novation Circuit to Roland A-01: i can only use one, causue all together, they even each other out
My question how can i put the mtogether so they work at the same time
sjcaldwell
Power User
Post by sjcaldwell » Fri Jan 06, 2017 7:16 pm
You will either need 3 global variables (one for each channel), or you can use one global variable and use a bit map to determine which channel(s) you want to enable/disable.
global variable option g0 for channel 1 g1 for channel 2 and g2 for channel 3
Or have something like ga for all (to save consuption of global variables)
bit 0 = channel 1 enable = value 1
bit 1 = channel 2 enable = value 2
bit 3 = channel 3 enable = value 4
I posted more detail on the bitmap methodology somewhere else on this forum. If you can't find it, let me know and I will point you to it.
an3
Power User
Post by an3 » Fri Jan 06, 2017 7:34 pm
no i mean the octave transpose preset, the channel on/of preset and this one together
Bome Software: Founder
Contact:
Post by florian » Mon Jan 30, 2017 7:01 am
Hi an3, could you please your project file if the transpose issue still exists?
Post Reply
