Only 255 pixels?
Moderator: florian
Locked
NoNameNeeded
User
Only 255 pixels?
Post by NoNameNeeded » Mon Dec 26, 2005 7:13 pm
I just bought Restorator because I thought it would be more practical to replace resources than with Reshacker.
But now I found out that Restorator doesn't accept icons larger than 255 pixels...
That's a bit annoying because now I have to replace every icon one by one with Reshacker (it works with Reshacker!).
The reason why I need icons larger than 255pixels is because I want to replace the WinXP Icons with the ones from Vista (256pixels).
It would really be nice if Restorator could accept icons of that size...
Bome Software: Founder
Contact:
Post by florian » Mon Jan 02, 2006 7:00 pm
sorry for this problem and thanks for the report.
Icons proved as quite complicated often enough...
I'll try to fix this for the next (due soon) or over next version.
bip
New User
Post by bip » Mon Oct 12, 2009 12:21 pm
I've noticed a similar problem. When I open an EXE with Restorator, and then save it, regardless of what I change, it reduces the icon size and depth.
Contact:
Post by florian » Mon Nov 16, 2009 12:46 pm
this is fixed. If you own a license of Restorator, please contact me directly ( http://www.bome.com/contact.php ) to obtain an interim update version. Otherwise, wait for the next version.
Locked
