Prevent value 'jumping' by translating absolute MIDI CC into relative -1/+1 values
Post Reply
MIDIOnSKY
User
Post by MIDIOnSKY » Sat Apr 25, 2015 9:14 am
Hello BMT users!
I've searched this forum about this topic, but couldn't find a proper explanation of 2 things.
What do I want to achieve is to prevent my endless encoders from a midi controller to send out a fixed MIDI CC values to plugins and external hardware.
Instead, it should send incremented CC values as +1 or -1, depending if the encoder is turned left or right.
My midi controller supports 'relative mode' meaning that it can send a fixed CC value depending on which side encoder is rotating.
I need this CC message:
B0 09 41
to be translated into MIDI CC -1 relative value;
B0 09 01
to be translated into MIDI CC +1 relative value;
The missing variable, beside the BMT preset settings I'm asking for here, is the data for relative +1 or -1 CC values output as well. Although I found some info about this at the MIDI Manufacturers Association website
midi.org/techspecs/rp18.php
I'm not compleatelly sure about the values needed.
It should work regardless of targeted midi channel of course.
I hope that some guru can solve this dilemma :shock:
Many, many thanks in advance!
Cheers.
Bome Software: Founder
Contact:
Re: Prevent value 'jumping' by translating absolute MIDI CC into relative -1/+1 values
Post by florian » Sat Apr 25, 2015 10:53 pm
Hi MIDIOnsky!
have you checked out this thread?
Converting endless knob to absolute controller
My second example (for the Alphatrack) seems to be exactly what you need.
Best regards,
MIDIOnSKY
User
Post by MIDIOnSKY » Sun Apr 26, 2015 2:41 am
florian wrote:Hi MIDIOnsky!
Best regards,
I've tried that one, however destination parameter value do actually just stuck on 64/65 value. And they are just moving -1/+1 on that values.
Not sure that we understand each other though?
Any assistance would be highly appreciated.
Cheers.
DvlsAdvct
Bome Software: Partner
Post by DvlsAdvct » Sun Apr 26, 2015 7:38 pm
Hi MIDIOnSky
Can you attach your project here so I can look and see what's going on?
Jared
MIDIOnSKY
User
Post by MIDIOnSKY » Mon Apr 27, 2015 12:07 am
DvlsAdvct wrote:Hi MIDIOnSky
Jared
Sure, here you go.
The destination parameter still jumps as when using absolute MIDI CC values. Strange. Hope you can check this out.
Cheers.
Absolute to Relative MIDI CC.bmtp
(673 Bytes) Downloaded 191 times
MIDIOnSKY
User
Post by MIDIOnSKY » Wed Apr 29, 2015 4:18 am
Any news on this? I would really appreciate any help.
sjcaldwell
Power User
Post by sjcaldwell » Tue Aug 22, 2017 8:02 pm
Looking back at this old post. I updated your request with a workable solution. Any turn right will put out 01. Any turn left will put out 7F (127)
From-Old-Forum-Absolute to Relative MIDI CC-fixed-2017-08-22.bmtp
(1.2 KiB) Downloaded 146 times
MIDIOnSKY
User
Post by MIDIOnSKY » Wed Aug 23, 2017 3:33 am
Will check this out and let you know! :)
Thanks a lot.
Post Reply
