Display Menu IDs in positive numbers
Moderator: florian
Locked
Yaron
New User
Post by Yaron » Wed Jan 15, 2014 1:29 am
How can I set Restorator to display Menu IDs in positive numbers?
Instead of:
MENUITEM "E&xit", -7871
Display:
MENUITEM "E&xit", 57665
Thank you.
Bome Software: Founder
Contact:
Re: Display Menu IDs in positive numbers
Post by florian » Tue Feb 25, 2014 8:17 pm
hi yaron, unfortunately that's not possible. You can just subtract the negative number from 65536 to get the positive value. Internally, they are equivalent.
Yaron
New User
Post by Yaron » Wed Feb 26, 2014 2:48 am
Thanks for replying.
When localizing a program with an external file, subtracting the negative number from 65536 (for each string) is not convenient.
If you plan to update Restorator, please remember this issue. :)
Yaron
Locked
