Some key combinations do not work
General discussion about Bome's Mouse Keyboard
Moderator: florian
Locked
gabrielconroy
New User
Post by gabrielconroy » Tue Apr 14, 2009 2:53 pm
I have Mouse Keyboard set up through Maple MIDI into Reason 4, and it works fine except for one thing: on some combinations of notes, I can't get a particular ntoe to sound.
For example (and this isn't necessarily the particular combination): I play and hold Eb-F-A, then go to play a D on top of that chord, but it won't sound until I've released one of the notes from the initial chord. This happens in a number of combinations.
I don't think it has to do with the number of notes, because that can vary.
Any ideas?
Bome Software: Founder
Contact:
Post by florian » Wed Apr 15, 2009 8:33 am
unfortunately, this is a limitation of computer keyboards. Internally, they use a matrix to capture the keys. Usually, only 3 or 4 keys at once can be played. Sorry!
gabrielconroy
New User
Post by gabrielconroy » Wed Apr 15, 2009 9:01 am
OK, thanks for the prompt reply. I guess I'll just set up two instruments, and use two voices instead of one.
Contact:
Re: Some note combinations not sounding in Reason 4
Post by florian » Mon Nov 02, 2015 1:06 pm
just as a side note: there are gaming keyboards which are, apparently, able to produce more key combinations.
Locked
