Alternating possible?
Post Reply
Ozarkeys
Power User
Post by Ozarkeys » Sat Jan 06, 2007 9:52 am
Just curious if it's possible to set up alternating notes say like for up and down stroke strings. Each time the note is pressed it alternates to another note of choice. Let me know. Thanks
--Ozarkeys
Bome Software: Founder
Contact:
Post by florian » Sun Jan 07, 2007 9:14 pm
this is possible with the Rules feature of Midi Translator Pro: just define one global variable (e.g. "ga") as alternator between 0 and 1. Then define 2 translators of which one is only executed if ga is 0, and the other only if ga is 1:
Translator 1: Alternator
Options: stop=false
Incoming: MIDI 90 40 qq
  if qq==0 then exit rules, skip Outgoing Action
  ga=1 - ga
Outgoing: (none)
Translator 2: Note On for ga=0
Options: stop=false
  if ga!=0 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 41 qq
Translator 3: Note On for ga=1
Options: stop=false
  if ga!=1 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 42 qq
In the example, the trigger note is hexadecimal 0x40 (note E), it triggers all 3 translators. In an alternating fashion, note 0x41 and 0x42 are triggered instead. Note that a velocity of 00 is a Note Off. The Alternator Translator Entry does not change the ga flag upon a Note Off, but you may run into problems if the Note Off is not issued before the next Note on. Also, the script would need to be extended if your keyboard sends actual Note Off messages (i.e. status 0x80).
Hope that helps!
Ozarkeys
Power User
trouble with this one...
Post by Ozarkeys » Mon Jan 08, 2007 10:15 pm
Couldn't get this one to work. My keyboard does send note off (80) with varying note off values (0-127) depending on how fast you let off the keys. It's a Roland A-90. Any ideas? Thanks for your help.
--Bransonkeys
admin
Site Admin
Post by admin » Tue Jan 09, 2007 2:19 pm
if your keyboard uses actual note off messages, the MT preset needs to extended with these 2 translator entries:
Translator 4: Note Off for ga=0
Options: stop=false
Incoming: MIDI 80 40 qq
Outgoing: MIDI 80 41 qq
Translator 5: Note Off for ga=1
Options: stop=false
Outgoing: MIDI 80 42 qq
I guess the additional translators are straight forward. You could combine translators 2-5 in one single translator with additional rules, but I guess for a start, this is easier to understand.
If it still doesn't work, please be as precise as possible what works and what doesn't work.
Ozarkeys
Power User
still not working...
Post by Ozarkeys » Wed Jan 10, 2007 12:51 am
The note on and off doesn't seem to be the problem. The alternator code doesn't seem to alternate. If I put in: If ge==0 then ge=1,
If ge==1 then ge=0, the ge value stays stuck on 0. If I put in: If ge==1 then ge=0
If ge==0 then ge=1, the ge value stays stuck on 1. I followed every detail.
Thanks for your help--
Ozarkeys
Contact:
Post by florian » Wed Jan 10, 2007 2:43 am
ooops! you're right! it's so stupid I can't leave it there :)
So I've edited my actual post above with the fix.
I've just edited Translator 1.
Later,
Ozarkeys
Power User
Awesome!!...What about more than 2 layers?
Post by Ozarkeys » Wed Jan 10, 2007 10:32 pm
Got it working now. Thanks for the help. What about if I want to alternate between more than two layers? Say 3 or 8 layers.
---Ozarkeys
Contact:
Post by florian » Thu Jan 11, 2007 12:56 am
you can extend the scheme above easily for more values of ga. For example, to have 5 distinct mappings that are cycled through, replace Translator 1 above with this:
Translator 1: Change to next value of ga
Options: stop=false
  ga=ga + 1
  IF GA >= 5 THEN ga = 0
Outgoing: (none)
Now each press of key 0x40 will increase ga by one until it reaches 4. The next time it will be increased to 5, but the last IF statement will reset it to 0. So the ga variable will always be in the range [0...4].
Now for every value of ga you can create an own mapping, e.g. to play note 0x50 when for ga is 2:
Translator 6: Note On for ga=2
Options: stop=false
  if ga!=2 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 50 qq
Translator 7: Note Off for ga=2
Options: stop=false
Outgoing: MIDI 80 50 qq
If the outgoing MIDI numbers are calculable (i.e. just chromatic keys), you can use a rule to calculate it. For example, you want to cycle through notes 0x50, 0x51, 0x52, 0x53, and 0x54. Then use this set of Translator entries:
Options: stop=false
  ga=ga + 1
Outgoing: (none)
Translator 2: Note On for any value of ga
Options: stop=false
  pp = 0x50 + ga
Outgoing: MIDI 90 pp qq
Translator 3: Note Off for any value of ga
Options: stop=false
  pp = 0x50 + ga
Outgoing: MIDI 80 pp qq
As you can see, the new note number is calculated by adding 0x50 to ga, storing the result in pp. Then, the note parameter of the OUTGOING MIDI command is just set to pp. Using this scheme, you can also use more complicated setups, e.g. cycle through every 2nd note can be done using these rules in Translator 2 and 3:
vv = ga * 2
pp = 0x50 + vv
I think you see how it works...
Post Reply
