Midi to Serial (COM)
Post Reply
frfortes
New User
Post by frfortes » Thu Nov 23, 2006 11:24 pm
What about a MIDI to Serial message (COM) Converter? It could be used to control different stuffs as controlable video players, projectors, and so one...
Bome Software: Founder
Contact:
Post by florian » Fri Nov 24, 2006 12:37 pm
yes, that's a good idea, I've added it to the feature request list. Would you have an example what kind of commandos would be sent over the serial port?
frfortes
New User
Post by frfortes » Fri Nov 24, 2006 9:56 pm
Normally I use some Pioneer standard serial comands, something like 1PL<CR> = Play Clip one + carriage return. You could set the COM preferences as baud rate, parity, bit depth and port. Multiple COM ports could be a very usefull ShowControl feature. For example, a NOTE ON C1 could be translated to PL1<CR> on COM1, and NOTE ON C2 could be PL2<CR>on COM2, user configurable. Got the idea? Very smilar of MIDI to keystroke comands, but instead of keyboard comands, serial ASCII comands... If multiple COMs is a problem, that's ok, just one will be very usefull! Thanks!
Post Reply
