How can I........
Post Reply
-fortune-
User
How can I........
Post by -fortune- » Sat May 20, 2006 7:35 am
I'd like to send 2 controllers with a knob (encoder) alternating between them with a button, i mean:
Button OFF = encoder send midi CC 34
Button ON = encoder send midi CC 60
I hope you standed me Florian, thanks a lot.
Bome Software: Founder
Contact:
Post by florian » Sat May 20, 2006 10:12 am
Please clarify knob, encoder, button: are they hardware or software? Is the knob a hardware knob on a MIDI controller?
Can you describe the full setup that you want to use? That'll make it much easier to understand.
-fortune-
User
Post by -fortune- » Sat May 20, 2006 3:30 pm
wow! thanks for your fast reply florian
I recently bought a Novation Remote 25 SL http://www.midiware.com/prodotti/immagi ... teSL25.jpg to control Ableton Live 5.
As you can see in the picture the Novation in the left side has 2 knobs, 2 buttons and 1 drumpad on every channel. In my set up the higher knob controls a LP filter and the bottom knob a HP filter in one template and in other template each knob controls the sends to the FX, ok?
i'd like to use just 1 template and control the "sends" without changing the template using the higher button on every track like Moldover does in this video http://www.moldover.com/video/moldover_lrmash_dv5.mov he uses reaktor to do it but i'd like to know if it could be possible with MT.
E.G:
button sends CC 100 in channel 4
ON=B3 64 7F
OFF=B3 64 00
knob sends CC 60 in channel 4 to control LP filter
B3 3C pp
I'd like the knob sends CC 70 when the button is ON (B3 64 7F).
Thanks Cheers.
Contact:
Post by florian » Sun May 28, 2006 10:06 am
Hi fortune,
sorry for the late reply...
Version 1.40 of Midi Translator can only do static translations. You could theoretically solve your problem switch presets, based on the state of the button: as outgoing action of the button ON press, change to a preset that translates the knob. On button OFF, change back to the other preset. But I guess there is more than one button...
...however, I just completed initial "Conditionals" support in the development version of "Midi Translator Pro". If you have purchased Midi Translator, you can request a preview of this feature. Now with it, your Translators could look like this:
Translator 1: evaluate button
Incoming: MIDI B3 64 ga
Outgoing: <none>
Translator 2: Translate CC60 to CC70 if button is ON
Incoming: MIDI B3 3C pp
Rule: IF ga=00 THEN "skip this translator"
Outgoing: MIDI B3 46 pp
Explanation:
Translator 1 sets a global variable (a variable that keeps its value for subsequent Input events) to the value of the button, i.e. 00 or 7F.
Translator 2 uses the new conditional feature: before executing the Outgoing Action, it checks if ga has the value 0. If yes, then it will not execute this Translator's Outgoing Action.
More info how to obtain pre-release versions:
http://www.bome.com/forums/viewtopic.php?t=178
Post Reply
