4x4 drum pad for Ableton 7
Post Reply
quoke
New User
Post by quoke » Tue Nov 20, 2007 3:36 am
Howdy,
I just setup MT to trigger an Ableton 7 drum rack using the computer keyboard; thought others might want it. I'd imagine this could be used with other software expecting inputs from a 4x4 drum pad as well.
The trigger keys are
1 2 3 4
Q W E R
A S D F
Z X C V
Also, pressing "G" moves the 4x4 pad up to the next higher virtual drum pad (by increasing each of the pads note value by 16), and "B" moves down the next lower virtual drum pad.
The velocity starts at 64. Hitting "H" will increase the velocity of future notes by 10. Hitting "N" will decrease it by 10.
Here it is [edited by florian]:
Download the preset file here for MT Pro, Author, and Player.
Unzip it into "My Documents\Bome's Midi Translator\" and open it from MT.
Bome Software: Founder
Contact:
Post by florian » Tue Nov 20, 2007 11:39 am
Hi quoke,
awesome! thanks for posting this preset.
I took the liberty to create a signed preset from it and put it up as a download on the server.
Best,
Post Reply
