Note On msg to output CC msg that increases +1 on each press
Post Reply
rishi
Power User
Post by rishi » Thu Nov 01, 2007 11:42 am
Hi Florian,
How do I get a Note On message to output a CC Controller message that increases by 1 each time I press it ?
I guess I need to store a value and then +1 each time the incoming Note on message is hit, but I cant get it to work?
I want one button to send +1 and one button to send -1.
Also, is it possible to use a timer to send multiple +1 or -1's if I hold the button down?
This is similar to my keypress thing but this time the output is a CC Controller message instead of a keystroke.
Bome Software: Founder
Contact:
Post by florian » Mon Nov 05, 2007 1:45 pm
Hi Rishi,
yes, that's no problem with MT Pro. This is very similar as converting an "endless knob" to a continuous controller (there are several threads about this in the forum). Here is a working solution for you, with repeat feature:
Translator 1: Note On 1: increment controller 07
Options: stop=false
Incoming: MIDI 90 45 pp
  Label "Ignore if Note Off"
  if pp==0 then exit rules, skip Outgoing Action
  Label "Cannot increase anymore if already 127"
  if gc>=127 then exit rules, skip Outgoing Action
  gc=gc+1
Outgoing: MIDI B0 07 gc
Translator 2: Note On 1: start timer
Options: stop=false
Outgoing: Periodic timer "Note On 1": 100 ms (initial delay: 500 ms)
Translator 3: On Note 1 timer: increase gc and output controller
Options: stop=false
Incoming: On timer "Note On 1"
  gc=gc+1
Translator 4: Note On 1: stop timer
Options: stop=false
Incoming: MIDI 90 45 00
Outgoing: Kill timer "Note On 1"
Translator 5: Note On 2: decrement controller 07
Options: stop=false
Incoming: MIDI 90 43 pp
  Label "Cannot decrease anymore if already 0"
  if gc<=0 then exit rules, skip Outgoing Action
  gc=gc-1
Translator 6: Note On 2: start timer
Options: stop=false
Outgoing: Periodic timer "Note On 2": 100 ms (initial delay: 500 ms)
Translator 7: On Note 2 timer: decrement controller 07
Options: stop=false
Incoming: On timer "Note On 2"
  gc=gc-1
Translator 8: Note On 2: stop timer
Options: stop=false
Incoming: MIDI 90 43 00
Outgoing: Kill timer "Note On 2"
rishi
Power User
Post by rishi » Wed Nov 07, 2007 12:08 am
Thanks so much!!
I saw elements of what I was trying to do in the endless knob threads but couldnt get it to work. Will try this out now!!
Post Reply
