Hex numbers: MT Pro Description question
Post Reply
Max Oepen
Power User
Post by Max Oepen » Fri Oct 12, 2007 9:55 am
Hi there.
seems that MT Pro translates Hex versions of notes an octave higher in its description.
Why is that??
for example:
If I enter: 99 2A oo (2A representing Midi note# 42 = F#1), MT Pro describes it as "F#2"!
This only seems to be an issue with the description though, since it still receives/ sends the correct event. So, if I set the above (99 2A oo) as the outgoing Midi message, it does in fact send out on F#1.
Since the description does not correspond to the note played, this can get confusing.
Please comment.
Max.
Bome Software: Founder
Contact:
Post by florian » Wed Oct 17, 2007 7:28 am
Yes, the octave number is not entirely standardized for MIDI notes - the MIDI standard only recommends that note number 60 (=3C hex) is "middle C". MT (and other programs) refer to this as C4, while other programs will display it as C3. And maybe even other ways of "counting" the octave.
I'll note that this should be user customizable.
Post Reply
