pitch bend remapped and relaid out?
Post Reply
Ozarkeys
Power User
Post by Ozarkeys » Tue May 22, 2007 12:08 am
Any easy way with the variables to convert pitch bend in it's 14bit glory to CC#11 and THEN, map so that all the way left is 0, center is 127, and all the way right is 0. Basically I'm using to crossfade a Stanton CD scratcher. My big keyboard assigns easily to this however I thought I'd set up a preset to use any keyboard bender to do this. Thanks for your help.
Ozarkeys
Ozarkeys
Power User
Got it...
Post by Ozarkeys » Fri Jun 01, 2007 11:17 pm
I figured it out, never mind.
Any idea on when the full version will be out?
thanks,
---Ozarkeys
Bome Software: Founder
Contact:
Re: Got it...
Post by florian » Mon Jun 04, 2007 8:39 pm
Ozarkeys wrote:Any idea on when the full version will be out?
not too distant from now. MT Pro beta is very stable, no significant bug reports so far. So we worked on the UI and features :)
First, though, expect a new beta.
Post Reply
