Varible Timers - Are they possible ?
Post Reply
Richard Soup
User
Post by Richard Soup » Thu May 03, 2007 11:10 am
Hi - I am trying to set up a timer that is dependant on the tempo of Abelton.
The Tempo would be set by a controller coming in and the timer delay would be callculated on the basis of this.
I have a fairly complex set of translators - I have set up an Abelton Midi Clip to record a 4 bar sequence.
I want various commands to be sent out at the end of these 4 bars - But Abelton cannot send out different data to different channels from one clip - Hence the need to send out delayed data via BT.
Hope this makes a sort of sence
If Varible timers are not possible - It would a great feature in future.
All the best
Richard - www.soupsounds.com
Bome Software: Founder
Contact:
Post by florian » Mon May 07, 2007 2:12 pm
Hi Richard,
the next version of MT Pro will allow timers to be set with variables, so you will be able to calculate the delay for the timers.
timothyallan
User
Variable Timers #2
Post by timothyallan » Mon Aug 20, 2007 12:14 pm
I am 1 step away from having a working competitor to the pushandpull program for Live. All I need is a timer that will execute GA times depending on other criteria.
Is this going to be possible with the new version?
Cheers,
Tim
Contact:
Post by florian » Tue Aug 21, 2007 12:19 am
Hi Tim,
yes, this feature is already implemented and a new beta is just around the corner!
Post Reply
