using it with HogPC
Post Reply
abbas
New User
using it with HogPC
Post by abbas » Mon Feb 20, 2006 12:47 am
I have set up the system and it will work in word docs etc. but when I try to use it with Wholehog 2 pc (free from www.flyingpig.com) Nothing comes up like it isnt receiving the information. The program responds to the keyboard but not to the midi translater. What could be causing this and is there anything I can do to get around it.
thanks
abbas
Bome Software: Founder
Contact:
Post by florian » Mon Feb 20, 2006 9:17 am
It is probable that the Wholehog software accesses the keyboard in a non-standard way (i.e. low level) and therefore will not see the emulated keystrokes.
Currently, I don't see a way how this can be fixed, except in Wholehog -- you should ask them to fix Midi Translator support. I may come up with a solution in future, but this will take time.
Post Reply
