APC20 pad led feedback
Post Reply
b52productions
User
Post by b52productions » Sat Dec 24, 2016 5:46 pm
looking for methods to keep the leds on while this toggles in the program the led is turned off by hardware.. tried timer but looking for better options
thanks for any input
b52productions
User
Re: APC20 pad led feedback
Post by b52productions » Mon Jan 02, 2017 5:50 am
i get get proper led output while holding button... any suggestions on "rules" so that i can toggle led feedback as i will only have 1 note change at a time
Bome Software: Founder
Contact:
Post by florian » Mon Jan 30, 2017 6:49 am
yes, a simple way is this scheme:
Incoming: Note On, note pp, velocity qq
 g0=127-g0
Outgoing: Raw MIDI "90 pp g0"
The rules will toggle the value of g0 each time you press a note. Note that we use the Pro edition's "Note On" incoming MIDI action here, which will not trigger on Note Off (as would Raw MIDI "90 pp qq" do).
The action sends out a raw MIDI message with velocity g0, 127 being a Note On and 0 being a Note Off.
Note you need to use a separate global variable for every LED.
Post Reply
