Hardware: Connections not tight
Discussion about the BomeBox
Post Reply
CreepyPants
Power User
Post by CreepyPants » Sat Dec 03, 2016 6:11 pm
So, not sure if this is because I have the pre-production version or not, but my USB-mini that I have hooked up to the power likes to fall out and the USB connection from my hub is quite loose.
Was this an issue at all with pre-production models?
Anyone else with a pre-production model have this issue?
Think/know if it's resolved with the producetion model?
I have tape, but I imagine this will only be an issue at the worst possible times. heh heh
Bome Software: Founder
Contact:
Re: Hardware: Connections not tight
Post by florian » Sun Dec 04, 2016 12:49 am
Indeed, Micro-USB is not the tightest connection possible. At the time, we thought micro-USB is great because so many cheap power supplies are available. But some connectors don't hold tight. Pre-production models have the same connectors, so it depends on the plug you're using how tight you can get. Some cables are better than others.
If this really becomes a burden, use a Power-over-Ethernet Injector as a power supply. You need a 48V model, cheap ones are available as cheap as $15. The Ethernet cable won't fall out on its own.
CreepyPants
Power User
Post by CreepyPants » Sun Dec 04, 2016 1:55 pm
Thanks Florian!
BTW: going with a very standard micro-USB is brilliant. No dedicated power supplies to lose, misplace, get damaged & be without a device until a replacement is found! Or even if you forget to pack a power supply for a gig - someone will have a cell phone charger.
Post Reply
