Can a BomeBox appear on a CopperLan network?
Discussion about the BomeBox
Post Reply
xpander
New User
Post by xpander » Sat Nov 12, 2016 11:58 pm
Can a BomeBox appear on a CopperLan network, just like a computer? Is the BomeBox a Linux computer? Would it have the capacity to run an embedded install of CopperLan?
Bome Software: Founder
Contact:
Re: Can a BomeBox appear on a CopperLan network?
Post by florian » Sun Nov 13, 2016 9:58 am
the BomeBox is not specifically made for CopperLAN, and we do not know anything specific about this network protocol.
On the other hand, the BomeBox is running an embedded Linux indeed, and unless CopperLAN requires a lot of resources (memory, CPU), the BomeBox should be capable of running it. Our processes are often user-driven, so if there is enough demand, we may consider looking into this protocol and if it's possible (also legally) to add support. So far, we focus on adding OSC and RTP-MIDI.
Other than that, the BomeBox behaves like a standard Ethernet/WiFi network router and dual-port Ethernet switch, so any Ethernet protocol should work fine with the BomeBox as switch/DHCP server/etc.
JacobiusWrex
Power User
Post by JacobiusWrex » Tue Jan 10, 2017 11:35 pm
I just got my Bomebox connected and yes, it automatically appears on the list in copper lan :D
Post Reply
