Factory Reset
Discussion about the BomeBox
Post Reply
Hotchkiss
New User
Factory Reset
Post by Hotchkiss » Wed Sep 14, 2016 11:18 am
Hello !
I just received the BomeBox. Unfortunately, I did something stupid and now I can't access the Web interface anymore neither over Wifi nor Ethernet.
I first connected easily (over Wifi), then checked the box "Client" in the Wifi settings to see what it does (that's realy dumb because I know nothing about networks, hotspots, clients etc.) and I can't see the box since then.
I tried the .txt trick with two different sticks but it doesn't seem to make a difference.
So I'd like to know if it's possible to factory reset the box or something like that ?
Thanks for your help
Bome Software: Founder
Contact:
Re: Factory Reset
Post by florian » Fri Sep 16, 2016 12:59 am
Hi Hotchkiss,
sorry for the late reply! The factory reset is done by way of a USB thumb drive as explained in the instructions. It should reset the network to factory defaults.
You can also directly connect the BomeBox to a computer using an Ethernet cable.
If all that does not work, please contact us directly.
sjcaldwell
Power User
Re: Factory Reset
Post by sjcaldwell » Tue Oct 18, 2016 5:44 am
The name of the file that the bomebox creates is different than on the instructions 00012345_network_reset.txt is what the instructions say and the file generated is 0012345_reset_network.txt.
I copying the file so I had both file names on my thumb drive when I booted the bome box and the network reset worked OK.
Contact:
Re: Factory Reset
Post by florian » Tue Oct 18, 2016 10:31 am
Hi sjcaldwell,
you're absolutely right -- it's a bug in the instructions!
Best,
Post Reply
