nothing works
Moderator: florian
Locked
Gärtner
New User
nothing works
Post by Gärtner » Fri Dec 22, 2006 2:30 pm
Hi Florian,
I try to save bulk dump of my Dr-770 to my PC.
I have a soundblaster live value under win2000.
All I get to read in the in window is FE.
What does that mean?
Thanks for you help.
Regards
Dirk
Gärtner
New User
Post by Gärtner » Fri Dec 22, 2006 10:24 pm
trying to open youre link gives me a virus warning. !?!!??
Bome Software: Founder
Contact:
Re: nothing works
Post by florian » Tue Jan 02, 2007 4:48 pm
Hi Dirk,
Gärtner wrote:All I get to read in the in window is FE.
FE is the hexadecimal code for the Active Sensing MIDI message. In this context it is not useful and you can cancel its display by unchecking the Active Sensing in the options menu.
On the DR-770 there should be a way to start the bulk dump. Then Send SX should display the incoming bulk dump.
Regards and happy New Year,
Locked
