[SendSX 1.22] MIDI devices not remembered
Moderator: florian
Locked
Kaminari
User
Contact:
Post by Kaminari » Wed May 11, 2005 8:46 pm
Hi Florian!
SendSX is the perfect SysEx monitor for my Roland CM-500. Thanks for this great utility -- postcard pending 8)
I'm having a problem with 1.22 version. When I select my MIDI In and Out ports, they are saved in Registry after I quit SendSX; but when I run it again, In and Out ports are automatically reset to None, and I have to manually set them again (other settings like delay, window positions, etc are not affected). This is a minor issue but it's a bit frustrating after a while...
For the record, it works fine with 1.21 (which, I believe, uses a different set of Registry options). I'm under WinXP SP2.
Cheers,
Patrice
Bome Software: Founder
Contact:
Indeed...
Post by florian » Wed May 11, 2005 10:37 pm
I can reproduce that problem. Maybe you'd like to give version 1.30 a shot? I posted it at
http://www.bome.com/midi/sendsx/beta/
V1.30 comes with some nice enhancements, e.g. a real settings dialog...
Kaminari
User
Contact:
Post by Kaminari » Thu May 12, 2005 2:11 am
Thank you for the swift feedback!
Hooray, 1.30 solved the problem. Mostly excellent stuff in that new version too, like the more user-friendly MIDI speed throttling -- it works like a charm with my MidiSport Uno. I was thinking about a possible feature: is there any way to reuse an existing SendSX window (when double-clicking on a SysEx file) instead of having another one displayed?
Thanks again for the great support :)
Contact:
Post by florian » Thu May 12, 2005 7:44 am
sure, that's pretty easy.
I'll put it on the feature request list.
Locked
