Disable the file-advertissment about restorator when we buy
Moderator: florian
Locked
merovengien
New User
Post by merovengien » Tue Aug 16, 2005 7:07 pm
Helllo !! I'M French
I have modified a file with restorator trial, and saved it.I have buiying for many day the full Restorator 2005 version, and i would to disable the advertissement-File of the file modified by the trial version.
How do it ???
Le_Merovengien
Le MerovenGien
Bome Software: Founder
Contact:
Post by florian » Tue Sep 06, 2005 5:37 pm
There is no "undo" feature to remove the texts added/modified by the trial version (the trial version is for testing only, not for "real" projects).
Of course, you can remove the texts manually by loading the file into Restorator and edit the menu/dialog/version resources that have those texts added.
Locked
