Error: Double SEPARATOR entry in MENU resource
Moderator: florian
Locked
Trashman
User
Contact:
Post by Trashman » Wed Jun 15, 2005 8:48 am
At adjustment earlier translations in Restorator 2005 now at the entry menu display this:
MENUITEM SEPARATOR, SEPARATOR
Before installed Restorator 2005 build 3.5 was everything in order.
Because it reveal as far as after installation Restorator 2005 build 3.5, must it be set or entry, which used obe program version and Restorator 2005 build 3.5 it damaged. Uninstall Restorator 2005 build 3.5 won't help, error stay.
At comparison two sable show through, in mistaken set hexane issue 08, which in correct set isn't!
Ask therefore author programme Restorator, how this mistakes from system Windows remove?
Bome Software: Founder
Contact:
Post by florian » Wed Jun 15, 2005 9:34 am
You can get rid of this error by manually replacing all
with
MENUITEM SEPARATOR
Then commit and save.
I could reproduce this problem only by "hacking" a resource. I don't know how this could happen with your version of Restorator. Are you sure that you use an unaltered version from bome.com (note that a full version or a license key "found" on the Internet constitutes an altered version)? There is a beta version available for people who have purchased a license for Restorator.
Trashman
User
Contact:
Post by Trashman » Wed Jun 15, 2005 1:41 pm
After uninstallation of all version Restoratoru and erasure key Bomers, stays this error in system Windows.
At new installation every version Restoratoru error disply manifest.
Error is due damage Windows programme Restorator and his new installation already unremoved.
Trashman
User
Contact:
Post by Trashman » Thu Jun 16, 2005 7:52 pm
In transfer set, where portrayals error MENUITEM SEPARATOR, SEPARATOR be in hexane code issue 08. In set where error isn't is ibidem issue 00. When the in mistaken set repair numbers 08 on numbers 00 error abstracting. Where's in Windows set or entry in register, which using for mistaken display entries MENUITEM SEPARATOR, SEPARATOR ?
Trashman
User
Contact:
Post by Trashman » Sat Jun 18, 2005 10:37 pm
Write how mistakes that caused Restorator 2005 in system Windows repair, or I'll obliged description those mistakes publish on more servers.
Contact:
Post by florian » Tue Jun 21, 2005 1:28 pm
Trashman,
this is a confirmed bug. We have fixed it and future versions of Restorator will work correctly.
Users who have purchased Restorator are entitled to an interim update. All other users will have to wait for the next public update release.
Thank you very much for reporting this important bug.
Locked
