command line parameters
Moderator: florian
Locked
mike
New User
Post by mike » Thu Jan 13, 2011 10:41 pm
I am trying to run restorator from command line.
C:\Program Files (x86)\Restorator 2007>restorator.exe -open C:\Users\mraykhman\Desktop\ehres.dll -assignON "RCData\TWOFOOT.CONTROL.NEXT.NOFOCUS.PNG" C:\Users\mraykhman\Desktop\DISABLED.PNG -save
There is no errors but also resource TWOFOOT.CONTROL.NEXT.NOFOCUS.PNG is not replaced by DISABLED.PNG
When I try to create log file with -errorLog switch, it creates file but it's empty. What I am doing wrong?
Thanks in advance, Mike
Bome Software: Founder
Contact:
Re: command line parameters
Post by florian » Wed Apr 27, 2011 9:25 pm
Hi Mike,
have you figured this out by now? The command line looks fine. We usually use it with "-close" parameter, too.
rominalett
New User
Post by rominalett » Thu Sep 27, 2012 3:12 am
is this resolved?
Contact:
Post by florian » Mon Oct 01, 2012 9:58 am
I don't think there has ever been an issue with command line usage in Restorator. I assume the user above found his problem and resolved it (most likely some malformed parameter, forgotten quotes, etc.).
Locked
