How to replace some strings in a STRINGTABLE?
Moderator: florian
Locked
Anton
New User
Post by Anton » Wed Sep 13, 2006 8:12 pm
There are several strings in a STRINGTABLE, which are to be replaced with new ones.
New values are specified in RC file, for example:
STRINGTABLE
61354, "String_61354"
61355, "String_61355"
61358, "String_61358"
Original STRINGTABLE has also strings with other identifiers: 61353, 61357, etc.
If I feed new STRINGTABLE to the Restorator, it replaces entire original STRINGTABLE, removing the strings, which have no new values. But I don't want to change them...
How can I replace strings selectively?
By the way, why all strings are to be gathered into STRINGTABLE? Let them exist alone... though this would be a feature request :)
Bome Software: Founder
Contact:
Post by florian » Wed Sep 20, 2006 4:52 am
yeah, that's a good idea. I'll add it to the feature request list.
Of course you can edit string tables directly in Restorator...
Anton
New User
Post by Anton » Thu Sep 28, 2006 3:16 pm
florian wrote: Of course you can edit string tables directly in Restorator...
I do not use Restorator GUI directly - all replacements are performed via command line call during batch processing...
Hope, selective string relacement feature will be implemented soon :)
Locked
