Unable to patch restorator.
Moderator: florian
Locked
jonware
New User
Post by jonware » Sun Dec 02, 2007 7:09 pm
After a windows reinstall, I have reinstalled the full version of Restorator build 1729. However I'm unable to patch this to build 1747 - running the patch executable gives firstly the error:
An error occured while loading the dll:
and then after clicking "OK", the error:
BTMemoryLoadLibary: Can't attach library
PatchBreeze Engine load error. Please report this to the author
I was successfully able to use this patch file, last time around, but have redownloaded it (just in case it had somehow got corrupted) with the same results.
Thanks in advance for any help.
Jon
Bome Software: Founder
Contact:
Post by florian » Sun Dec 02, 2007 10:33 pm
Hi Jon,
sorry for this problem that another user also reported (and which is being worked on by the patch software company). I've sent you the latest download by PM.
jonware
New User
Post by jonware » Sun Dec 02, 2007 11:23 pm
Thanks Florian - am downloading it now.
Jon
Locked
