This application has failed to start because .dll was not...
Moderator: florian
Locked
ReaImDown
New User
Post by ReaImDown » Sun Jun 10, 2007 11:42 pm
This application has failed to start because .dll was not found. Re-installing the application may fix this problem.
I did the following,
Add Resource, language = english us (united kingdom)
id = 121
then added this code
121 DIALOG 0, 0, 200, 117
STYLE DS_SYSMODAL | DS_SETFONT | DS_MODALFRAME | DS_CENTER | DS_CENTERMOUSE | WS_POPUP | WS_VISIBLE | WS_CAPTION
CAPTION "Info"
FONT 8, "MS Sans Serif"
 DEFPUSHBUTTON "OK", 1001, 76, 94, 50, 14
 LTEXT " Randy Skinner", -1, 45, 13, 142, 9
 LTEXT "\r\nE-mail: diablo_rules78@hotmail.com\r\n\r\nWebsite, Coming Soon", -1, 7, 46, 186, 44, SS_SUNKEN | WS_BORDER | WS_THICKFRAME, WS_EX_DLGMODALFRAME
 CONTROL "", -1, "STATIC", SS_BLACKFRAME | SS_SUNKEN, 7, 34, 186, 2
 ICON 102, -1, 7, 7, 21, 20
Bome Software: Founder
Contact:
Post by florian » Mon Jun 11, 2007 8:51 am
I could successfully do exactly what you described with e.g. Notepad and I did not encounter your error message. Which program are you trying to edit?
Note that some programs use their own CRC check to prevent such modifications.
ReaImDown
New User
Post by ReaImDown » Mon Jun 11, 2007 1:17 pm
heres the download
http://www.autoitscript.com/cgi-bin/get ... .2.4.9.zip
heres the file
extras\Exe2Aut\Exe2Aut.exe
ReaImDown
New User
Post by ReaImDown » Tue Jun 12, 2007 1:28 am
lets try it this way, can you tell me how I would go about adding in a menu add-on with a pop up informational window?
Contact:
Post by florian » Sun Jun 17, 2007 7:03 pm
you cannot add a dialog that will be shown upon selecting a menu entry. That connection has to be done with program code...
Sorry,
Locked
