Dialogex problem in restorator 2006
Moderator: florian
Locked
Mikhail
New User
Post by Mikhail » Mon Feb 27, 2006 10:58 am
Restorator 2006 incorrectly saves font styles in DIALOGEX resources. (itallic parameter) . After saving (and reopening) - all signs in dialog becomes itallic.
I see one way to correct it at the moment - return to the restorator 2005 (it works ok ).
Bome Software: Founder
Contact:
Post by florian » Wed Mar 01, 2006 7:23 am
Hi Mikhail,
thanks for reporting this problem, it looks like a rather serious bug. I'll check it out.
Contact:
Post by florian » Wed Mar 01, 2006 7:28 am
I could reproduce this bug. It only happens when editing the RC text of the dialog. The graphical dialog editor works as before.
I'm working on a fix and I'll let you know here when an update is available.
Mikhail
New User
Post by Mikhail » Wed Mar 01, 2006 9:59 am
Hi Florian,
When porting the translation from one app. release to another i need to convert the resources to rc and back ( to see is there any differences in resources between releases).
By the way, could you add a resource comparison feature?
I think it is possible to improove the patcher algorithm to fscan and report the resource differences between two executables.
It would be a very useful feature.
Regards
Mikhail
Contact:
Post by florian » Wed Mar 01, 2006 11:51 am
I'm working on a translation software with built-in comparison and auto-translation of resources. That would probably solve your needs...
Contact:
Post by florian » Wed Mar 01, 2006 1:17 pm
We've posted an Update Patch for Restorator 2006 which fixes this bug. Please download it from http://www.bome.com/Restorator/update.html .
Please report if that fixes the issue.
Mok
New User
Post by Mok » Mon May 22, 2006 10:04 am
Not the same problem but similar. When I checked Restorator a few months back it was completely stripping font charset information from DIALOGEX definition. If original resource used something like this:
FONT 10, "Special Font", 0, FALSE, EASTEUROPE_CHARSET
Restorator removed the last parameter completely making the whole definition unusable (as default charset is ANSI). Was it fixed in 2006 edition?
Contact:
Post by florian » Tue May 23, 2006 11:08 am
Hi Mok,
indeed, Restorator still removes this flag. We weren't aware that you could add a charset setting to the FONT line. This should be added in the next version of Restorator. Please subscribe to the announcement list of Restorator to receive an update email when the feature is ready.
Locked
