Easier icon and file replacement
Moderator: florian
Locked
NoNameNeeded
User
Post by NoNameNeeded » Sat Jan 14, 2006 7:32 pm
This is what I would really appreciate:
  • On the left hand side you can choose the file that contains the bmps you want and on the right hand side you choose which bmp to replace.
Bome Software: Founder
Contact:
Post by florian » Mon Jan 16, 2006 7:36 am
you can do this to some degree by enabling "Single Icons and Cursors" in the advanced settings. You'll see a new resource hierarchy with one entry per icon format. You can drag .bmp's on these single icons to selectively only change that size/format icon.
Locked
