n3wb qu3st1on
Moderator: florian
Locked
G3N3R1C
New User
n3wb qu3st1on
Post by G3N3R1C » Fri Nov 25, 2005 7:51 pm
Ok, ive been looking around for a good resource editor, found it here :)
I wanted to customize my xp install with my own set of icons and dialog...
so far so good, ive modified the exe and dll files, compressed them to cab, put them where they go and install windows, only a few of my mods get through the install.... if i replace these files in safe mode manually it works, what am i missing here?
Bome Software: Founder
Contact:
Post by florian » Fri Nov 25, 2005 8:10 pm
Maybe Windows' installer has some kind of protection against "corrupt" installation files?
I'm not sure how that can be overcome, but windows customization experst will know, try
http://www.winmatrix.com
http://www.neowin.net/forum/index.php?s ... 78759&st=0
and I'm sure there are others.
Good luck!
Locked
