blyons
2013-05-15 00:49:04
Hi all,
I have a MIDI controller keyboard that I'd like to use the bottom octave for to rechannelize all outogoing data as follows:
1. Hit lowest key in bottom octave: All note on/note off above the first octave are sent out at channel 1.
2. Hit second lowest key in bottom octave: All note on/note off above the first octave are sent out at channel 2.
I know how to capture INCOMING note on message 90 g1 yy.
But, it doesn't look like it's possible to then use g1 in subsequent messages to pass outoing MIDI out to a variable channel:
OUTGOING: 9g1 xx yy.
Is this possible or should I try and rechannelize incoming MIDI Note On/Note Off a different way.
Thanks.
Thanks.
