Debrecini
2010-04-21 12:43:52
Hiya yesterday was my first day with MT Pro 1.7 beta for Mac OS X and I have made some very good progress but need help as I'm stuck with something.
I have used the SHIFT button on the APC to change BOME presets, I have 8 different presets or banks I can switch to by holding shift and pressing STOP CLIP buttons 1 through 8. My goal is to create something along the lines of the Native Kontrol Bome presets, however I want it customized to my taste with even more additional functions. http://www.youtube.com/watch?v=D4YIGfhb ... wXIUjxKKUo
So then on bank 1 I want the APC to function as normal but on all others 2-7 I want my own customized control.
Currently I've only worked on preset / bank 2 for which I've used BOME to create cursor keys on the APC I've even got them lighting up red, they flash when pressed and they scroll when held by utilizing Bome's repeat timers function.
The problem is when in Bome preset / bank 2 I don't want the APC40 to function in it's normal way at all, currently its still doing so. I have no idea of how to stop this behavior. In banks 2-7 I want all the CLIP LAUNCH buttons on the APC to stop launching Ableton clips and also to stop lighting up as if there is a clip on that button.
What I've done on bank 2 is very similar to 2:40 into that youtube video link I posted above. Notice how when he switches to this bank all the clip launch buttons on the APC stop lighting up as if clips are on the buttons. Instead they are only lit on buttons with functions he's added like cursor keys and zoom controls...etc
This is what I'm after but my lack of knowledge leaves me stuck at this point. Attached is my BOME Project so far.
Any help would be greatly appreciated.
- Attachments
- BOME APC 40.bmtp
- (13.01 KiB) Downloaded 455 times
