gabriels
2009-08-28 07:54:45
In Ableton, I'd like to control sample transpose (the control in the sample display window) with the note on messages from my midi keyboard. This doesn't work. When I try to map a range of notes to the (virtual) sample transpose knob in the sample window it only accepts the last note played.
As an alternate strategy, I tried using midiox to generate midi cc values. So, I might generate a cc value of 36 when I played C2, A cc value of 37 when I played C#2, etc. This served the purpose generally. The problem is that it produces a strange scale instead of a chromatic one when I play a series of consecutive notes. The result is a slightly compressed scale that ens up encompassing only 11 half steps if I play 12 consecutive notes
I think the solution would be to generatenthe correct 14bit cc values in response to note on messages but I can't figure out how to do it.
Can someone help?
Gabriel
Can someone help?
Gabriel
