stoecklem
2007-03-03 08:16:43
Hello
I was wondering what might be the best way to be able
to push a button(MIDI note on or keystroke) and then have that trigger a continuous controller fading from 0-127 at a defined rate. I push it again then it triggers the same fade each time.
I havent used MT in awhile, but I know that it might now include simple math, which you can increase the fader in increments triggered by timers.
It seems like this might require a lot of translators. Is this the only way to do this?
thanks
thanks
