Mikael
2016-12-30 14:39:02
I specify some general channel and controller numbers as global vars.
Now I want to use a global var in an Incoming MIDI trigger.
I do not want the value of the specified var to be set to the incoming MIDI value, but I want the var to define how the trigger has to look like.
For instance:
global var:
g1 = 0x12
trigger MIDI expression:
9D g1 7F
I want the translator to be triggered only if the received MIDI is "9D 12 7F".
Right now the expression acts as if g1 is a local var and the translator is triggered by any value in place of "g1". This makes perfect sense if a local var is used. A global var should act like a value in this place.
Is there a way to achieve this right now?
regards!
Mikael
For instance:
global var:
g1 = 0x12
9D g1 7F
regards!
Mikael
