cashperkins
2016-09-28 01:38:22
So I'm using Bome Midi Translator at the latest version, v1.8.1 in combination with an Allen & Heath GS R24m 24ch mixing console and an Allen & Heath analog interface. I'm connecting the IN and OUT of the analog interface to a Digidesign MIDI I/O on port 9 (both IN / OUT). Prior to the update, when using the trilian spectrasonics plugin (bass plugin), it had no problems, however after the update now trilian seems to pick up the ping from BOME translator communicating with the R24m mixing console. This creates a very loud low rumble note that seems to be played at the same time as the ping. Remember this was not an issue before the update. Does anyone have any suggestions on how to fix this problem? Or know whether it would just be better to revert back to an older version of BOME?
If a revert to an older version is the answer, how is this done?
I am running Pro Tools 10 HD3, and I'm using Trilian on an instrument channel, it doesn't matter what midi input channel I assign to it, all midi channel inputs to the instrument channel cause the ping to play a bass note
Thanks to anyone who can help me out!
